[mapguide][MG420][Modified] Global installer workaround: Add hardcoded string to branch ...
Bruce Dechant bruce.dechant at autodesk.com
Tue Oct 10 12:56:55 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG420
Type:
Defect
Artifact ID:
MG420 (Global installer workaround: Add hardcoded string to branch only)
Modified by:
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
The following modifications were made to this artifact:
-- Build set to new value:
178.61
-- Resolution set to new value:
Submitted
-- Status Explanation set to new value:
Code submitted.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Resolution Description set to new value:
Code submitted.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
