[mapguide][MG423][New] MgFeatureService::ExecuteSqlQuery(...) does not return the G...
Ronnie Louie
ronnie.louie at autodesk.com
Thu Oct 12 14:00:11 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG423
Type
Defect
Artifact ID
MG423 (MgFeatureService::ExecuteSqlQuery(...) does not return the GEOMETRY information)
Reported by
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Target milestone set to new value
1.0.2
- Subcomponent set to new value
Feature Service
- Steps to Reproduce set to new value
- Using MgFeatureService::ExecuteSqlQuery(...) to query features with a select statement.
- select statement: select * from coast_n83 where COASTLIN_1 = 6
- result: the Geometry information is empty in the xml.
- expectation: all the feature attributes should return.
- Priority set to new value
P2
- Summary set to new value
- Description set to new value
- Related Artifacts set to new value
MG384
- External ID set to new value
840153
- Version set to new value
1.0.1
- Artifact created
- Artifact Status set to new value
New
- Component set to new value
Server
- Defect Severity set to new value
High
- Build set to new value
178.62
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
