[mapguide][MG424][New] Add "|" delimiter to AttributeRelate, add primary Join name ...
Alexander Frumkin
alexander.frumkin at autodesk.com
Thu Oct 12 18:52:51 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG424
Type
Enhancement
Artifact ID
MG424 (Add "|" delimiter to AttributeRelate, add primary Join name to RelateProperty)
Reported by
Alexander Frumkin
frumkia (alexander.frumkin at autodesk.com)
New artifact details:
- Summary set to new value
- Priority set to new value
P3
- Artifact Status set to new value
New
- Artifact created
- Submission Reviewed set to new value
Yes
- Target milestone set to new value
1.1.0
- Description set to new value
Add <Primary_Join_name.Atribute_name> notation where a dot symbol “.” is used as a delimiter for the FeatureClassPropertyattribute value. Using name of a primary join (AttributeRelate) as a prefix indicates that this is a chained join. For conventional join there is no prefix.
Since there will be multiple places in the code that has to parse the FeatureClassProperty, the changes are suggested to the RelateProperty to support this functionality.
Add new optional AttributeNameDelimiter attribute to AttributeRelate. This is a string defaulted to "|".
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
