[mapguide][MG424][Modified] Add "|" delimiter to AttributeRelate, add primary Join name ...
Alexander Frumkin alexander.frumkin at autodesk.com
Thu Oct 12 18:58:48 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG424
Type:
Enhancement
Artifact ID:
MG424 (Add "|" delimiter to AttributeRelate, add primary Join name to RelateProperty)
Modified by:
Alexander Frumkin
frumkia (alexander.frumkin at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
ID MG424: Add "|" delimiter to AttributeRelate, add primary Join name to RelateProperty
Modified
File: trunk/MgDev/Common/MdfModel/AttributeRelate.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/AttributeRelate.cpp?view=diff&rev=880&p1=trunk/MgDev/Common/MdfModel/AttributeRelate.cpp&r1=879&p2=trunk/MgDev/Common/MdfModel/AttributeRelate.cpp&r2=880
File: trunk/MgDev/Common/MdfModel/AttributeRelate.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/AttributeRelate.h?view=diff&rev=880&p1=trunk/MgDev/Common/MdfModel/AttributeRelate.h&r1=879&p2=trunk/MgDev/Common/MdfModel/AttributeRelate.h&r2=880
File: trunk/MgDev/Common/MdfModel/RelateProperty.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/RelateProperty.cpp?view=diff&rev=880&p1=trunk/MgDev/Common/MdfModel/RelateProperty.cpp&r1=879&p2=trunk/MgDev/Common/MdfModel/RelateProperty.cpp&r2=880
File: trunk/MgDev/Common/MdfModel/RelateProperty.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfModel/RelateProperty.h?view=diff&rev=880&p1=trunk/MgDev/Common/MdfModel/RelateProperty.h&r1=879&p2=trunk/MgDev/Common/MdfModel/RelateProperty.h&r2=880
File: trunk/MgDev/Common/MdfParser/IOAttributeRelate.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfParser/IOAttributeRelate.cpp?view=diff&rev=880&p1=trunk/MgDev/Common/MdfParser/IOAttributeRelate.cpp&r1=879&p2=trunk/MgDev/Common/MdfParser/IOAttributeRelate.cpp&r2=880
File: trunk/MgDev/Common/MdfParser/IORelateProperty.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MdfParser/IORelateProperty.cpp?view=diff&rev=880&p1=trunk/MgDev/Common/MdfParser/IORelateProperty.cpp&r1=879&p2=trunk/MgDev/Common/MdfParser/IORelateProperty.cpp&r2=880
File: trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd?view=diff&rev=880&p1=trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd&r1=879&p2=trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd&r2=880
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
