[mapguide][MG425][New] invalid characters in filter cause web tier to crash
Paul Spencer
pspencer at dmsolutions.ca
Fri Oct 13 17:24:17 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG425
Type
Defect
Artifact ID
MG425 (invalid characters in filter cause web tier to crash)
Reported by
Paul Spencer
pagameba (pspencer at dmsolutions.ca)
New artifact details:
- Operating system set to new value
Windows XP
- Steps to Reproduce set to new value
In PHP, create a new MgQueryOptions object and call SetFilter with some non-ascii character like %fe decoded.
- Platform set to new value
PC
- Defect Severity set to new value
High
- Description set to new value
Setting a filter on an MgQueryOptions object can cause the web tier to hang if the filter string contains invalid characters.
This happened because I was passing a filter string from a browser that looked like '<field> = "%fer%"'.
When PHP decoded the string, it decoded %fe as a character (some wierd p thing) and then SetFilter caused the process to go off into outer space.
The desired behaviour would be to generate an exception.
- Component set to new value
Web Server Extensions
- Summary set to new value
- Priority set to new value
P3
- Artifact Status set to new value
Unconfirmed
- Artifact created
- Subcomponent set to new value
Feature Service
- Status Explanation set to new value
need someone to take a look at this.
- Version set to new value
1.0.1
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
