[mapguide][MG427][New] Coordinate system improvements
Bruce Dechant bruce.dechant at autodesk.com
Mon Oct 16 12:32:46 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG427
Type
 Enhancement
Artifact ID
 MG427 (Coordinate system improvements)
Reported by
 Bruce Dechant
 brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Description set to new value
  Add the following improvements to the coordinate system:
1) Make certain APIs case insensitive
2) Make some interanl APIs public
3) Add HTTP operations for coordinate system APIs
4) Add NEW API IsValid() for checking if an OGC WKT is supported.
5) Add support for LL84 coordinate system code
- Artifact created
- Justification set to new value
  Certain APIs are case sensitive and this makes them not very user friendly. Also, the other changes make using the coordinate system library easier and more effective.
- Priority set to new value
  P3
- Artifact Status set to new value
  New
- Summary set to new value
- Target milestone set to new value
  1.1.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
