[mapguide][MG428][Modified] Coordinate system libraries fail to initialize in web tier
Bruce Dechant
bruce.dechant at autodesk.com
Tue Oct 17 19:09:56 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG428
Type:
Defect
Artifact ID:
MG428 (Coordinate system libraries fail to initialize in web tier)
Modified by:
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
PROJ4 and GDAL require access to certain environment variables in order to function correctly.
They currently fail to read this settings correctly.
New value:
For Apache the following changes are required to http.conf:
SetEnv PROJ_LIB "Set to PROJ4 nad folder"
SetEnv GDAL_DATA "Set to GDAL data folder"
Add the following environment variables to the FastCgiServer entry in the http:conf:
-initial-env PROJ_LIB=PROJnadfolder
-initial-env GDAL_DATA=GDALdatafolder
Note: When setting the environment variables using "-initial-env" you cannot use spaces or enclose the folder in quotes or double quotes.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
