[mapguide][MG430][New] Labels for point symbols with off-center insertion point dra...
Traian Stanev traian.stanev at autodesk.com
Wed Oct 18 17:56:36 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG430
Type
 Defect
Artifact ID
 MG430 (Labels for point symbols with off-center insertion point draw wrong)
Reported by
 Traian Stanev
 traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
  Import a point layer and set a symbol with an off-center insertion point. Add labels. See bad things.
- Defect Severity set to new value
  Medium
- Priority set to new value
  P3
- Component set to new value
  Server
- Subcomponent set to new value
  Rendering Service
- Target milestone set to new value
  1.0.2
- Artifact created
- Version set to new value
  1.0.1
- Summary set to new value
- Description set to new value
  When a label is set on a point symbol that has an insertion point other than center (0.5, 0.5), the label is still anchored to the center point rather than the position of the actual symbol. Also, for rotated symbols, labels are anchored to the axis aligned bounds of the symbol, which sometimes results in the label being far away from the symbol.
- Operating system set to new value
  All
- Artifact Status set to new value
  New
- Platform set to new value
  All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
