[mapguide][MG430][Modified] Labels for point symbols with off-center insertion point dra...
Traian Stanev
traian.stanev at autodesk.com
Wed Oct 18 18:06:46 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG430
Type:
Defect
Artifact ID:
MG430 (Labels for point symbols with off-center insertion point draw wrong)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
The fix was done by Jason Nogar. Basically, we added a return value to the ProcessMarker API call. It's a bounding box that is optional and can be set by the Renderer::ProcessMarker call to contain the actual bounding box of the symbol, when insertion point is taken into account. Once this is known by the PointAdapter class, which determines the positions for the candidate labels for the point feature, it can do a better job calculating these and placing labels closer to the symbol. The fix also includes better handling for rotated symbols -- labels are now closer to the rotated symbol.
-- Review Comments set to new value:
[Traian] I don't like the complexity of some of the rotation math in PointAdapter, but we'll live with it I guess... since it does the job.
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Submission Reviewed set to new value:
Yes
-- Status Explanation set to new value:
A fix was submitted.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
