[mapguide][MG431][New] WebStudio: LineWidth set to incorrect expression for SLD poi...
Traian Stanev
traian.stanev at autodesk.com
Thu Oct 19 10:03:50 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG431
Type
Defect
Artifact ID
MG431 (WebStudio: LineWidth set to incorrect expression for SLD point symbols)
Reported by
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Priority set to new value
P3
- Description set to new value
I noticed this while debugging some unrelated stuff around point symbols. When creating a point symbolization using one of the 6 simple symbols, the line width property for the line stroke is set to "Solid", rather than 0. It seems to be just cut/paste typo.
- Component set to new value
Web Server Extensions
- Operating system set to new value
All
- Subcomponent set to new value
Web Studio
- Summary set to new value
- Version set to new value
1.0.1
- Artifact Status set to new value
New
- Defect Severity set to new value
Low
- Steps to Reproduce set to new value
Add a point layer and set the symbol to square. A bunch of exceptions will be thrown on the server side indicating the failure to parse the "Solid" string into a line weight. No other ill effect, just incorrect behavior.
- Platform set to new value
All
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
