[mapguide][MG432][New] Select on layer with join selects all objects
    Ronnie Louie
    ronnie.louie at autodesk.com
    Thu Oct 19 17:25:01 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG432
Type
 Defect
Artifact ID
 MG432 (Select on layer with join selects all objects)
Reported by
 Ronnie Louie
 ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Description set to new value
  Using Ajax viewer, selecting an object from a layer defined by a join, all objects are highlighted instead of just the intended one.
- Related Artifacts set to new value
  MG406
- External ID set to new value
  843175
- Component set to new value
  Server
- Defect Severity set to new value
  High
- Priority set to new value
  P2
- Summary set to new value
- Subcomponent set to new value
  Feature Service
- Target milestone set to new value
  1.1.0
- Artifact Status set to new value
  New
- Steps to Reproduce set to new value
  1.  Create a feature source that contains a join.
2.  Create a layer from that feature source.
3.  Create a map and weblayout respectively from the layer.
4.  Using Ajax Viewer, view the map and attempt to select some objects.  Notice all the object wil be selected.
- Version set to new value
  1.0.1
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
