[mapguide][MG432][Modified] Select on layer with join selects all objects
Ronnie Louie
ronnie.louie at autodesk.com
Thu Oct 19 17:31:27 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG432
Type:
Defect
Artifact ID:
MG432 (Select on layer with join selects all objects)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Build set to new value:
178.63
-- Resolution Description set to new value:
Identity properties were not retrieved for joined data. This resulted in all objects to highlight when performing selection.
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
