[mapguide][MG349][Modified] AJAX Viewer does not display multi-line labels
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Oct 20 05:24:59 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG349
Type:
Defect
Artifact ID:
MG349 (AJAX Viewer does not display multi-line labels)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Developer Notes set to new value:
Fixed a problem with DWF Viewer when rendering rotated multi-line labels. The text rotation was not being correctly account for.
-- Target milestone set to new value:
1.1.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
