[mapguide][MG435][New] Undo changes made in artifact MG333
Steve Dang
steve.dang at autodesk.com
Fri Oct 20 19:30:45 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG435
Type
Task
Artifact ID
MG435 (Undo changes made in artifact MG333)
Reported by
Steve Dang
stevedang (steve.dang at autodesk.com)
New artifact details:
- Artifact created
- Task Priority set to new value
Low
- Artifact Status set to new value
New
- Priority set to new value
P3
- Description set to new value
Undo changes made in artifact MG333 due to the following use case:
User A starts creating a map definition and defines some things about it, but not everything, because he needs to pass it over to the next user. One of these things that he doesn’t have information on yet is the coordinate system. Now Studio when it saves it cannot fill in a default CS (say “Arbitrary XY”) because that would be wrong, it needs to stay blank for the next user so that they know it is up to them to set the coordinate system. So we need to be able to have no CS defined for when things haven’t been finished yet.
- Target milestone set to new value
1.1.0
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
