[mapguide][MG436][New] Polygons with holes don't render correctly through KML servi...
Chris Claydon
chris.claydon at autodesk.com
Mon Oct 23 15:01:23 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG436
Type
Defect
Artifact ID
MG436 (Polygons with holes don't render correctly through KML service)
Reported by
Chris Claydon
chrisclaydon (chris.claydon at autodesk.com)
New artifact details:
- Description set to new value
Interior contours of poly-polygons render as additional solid polygons rather than being cut out as holes.
- Steps to Reproduce set to new value
Create a buffer layer around a road network, and render the layer using the KML service. The area within each closed road loop gets filled in too.
- Summary set to new value
- Version set to new value
1.0.1
- Component set to new value
Server
- Operating system set to new value
All
- Artifact created
- Defect Severity set to new value
Medium
- Subcomponent set to new value
Rendering Service
- Artifact Status set to new value
New
- Platform set to new value
All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
