[mapguide][MG432][Modified] Select on layer with join selects all objects
Ronnie Louie
ronnie.louie at autodesk.com
Tue Oct 24 18:27:57 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG432
Type:
Defect
Artifact ID:
MG432 (Select on layer with join selects all objects)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Developer Notes set to new value:
The original fix for selection broke the selection on joined data (MG406). The first fix with this artifact fixed the join case but broke the non-joined data. This final fix should take care of both joined and non-joined data. For both cases, the feature classes will be examined to determine the correct class to use for retrieving identity properties which are used when highlighting the selected feature(s).
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
