[mapguide][MG437][New] Allow dynamic long transaction names per connection
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Oct 25 09:31:41 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG437
Type
 Enhancement
Artifact ID
 MG437 (Allow dynamic long transaction names per connection)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Artifact created
- Priority set to new value
  P2
- Target milestone set to new value
  1.1.0
- Description set to new value
  MapGuide currently only supports a fixed long transaction name (LT name) per feature source, and this LT name is static for the duration of the connection.
MapGuide needs to be extended to support the following scenarios:
a) Multiple users connect to the same feature source, each using a different LT name
b) A user connects to a feature source, and later changes his active LT name
- Justification set to new value
  Enhances the use of long transactions.
- Summary set to new value
- Artifact Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
