[mapguide][MG437][Modified] Allow dynamic long transaction names per connection
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Oct 25 09:33:06 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG437
Type:
Enhancement
Artifact ID:
MG437 (Allow dynamic long transaction names per connection)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
MapGuide currently only supports a fixed long transaction name (LT name) per feature source, and this LT name is static for the duration of the connection.
MapGuide needs to be extended to support the following scenarios:
a) Multiple users connect to the same feature source, each using a different LT name
b) A user connects to a feature source, and later changes his active LT name
New value:
b) A user connects to a feature source, and later wants to change the active LT name for that connection
-- Artifact Status changed:
Old value:
New
New value:
Assigned
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
