[mapguide][MG363][Modified] Direct KML Support in MapGuide
Chris Claydon
chris.claydon at autodesk.com
Fri Oct 27 17:51:31 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG363
Type:
Enhancement
Artifact ID:
MG363 (Direct KML Support in MapGuide)
Modified by:
Chris Claydon
chrisclaydon (chris.claydon at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG363 - KML Service - Add KMZ support. Enhance stability.
Modified
File: trunk/MgDev/Common/Stylization/KmlContent.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/KmlContent.cpp?view=diff&rev=946&p1=trunk/MgDev/Common/Stylization/KmlContent.cpp&r1=945&p2=trunk/MgDev/Common/Stylization/KmlContent.cpp&r2=946
File: trunk/MgDev/Common/Stylization/KmlContent.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/KmlContent.h?view=diff&rev=946&p1=trunk/MgDev/Common/Stylization/KmlContent.h&r1=945&p2=trunk/MgDev/Common/Stylization/KmlContent.h&r2=946
File: trunk/MgDev/Common/Stylization/KmlRenderer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/KmlRenderer.cpp?view=diff&rev=946&p1=trunk/MgDev/Common/Stylization/KmlRenderer.cpp&r1=945&p2=trunk/MgDev/Common/Stylization/KmlRenderer.cpp&r2=946
File: trunk/MgDev/Server/src/Services/Kml/Makefile.am https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Kml/Makefile.am?view=diff&rev=946&p1=trunk/MgDev/Server/src/Services/Kml/Makefile.am&r1=945&p2=trunk/MgDev/Server/src/Services/Kml/Makefile.am&r2=946
File: trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp?view=diff&rev=946&p1=trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp&r1=945&p2=trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp&r2=946
File: trunk/MgDev/Server/src/Services/Kml/ServerKmlService.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Kml/ServerKmlService.h?view=diff&rev=946&p1=trunk/MgDev/Server/src/Services/Kml/ServerKmlService.h&r1=945&p2=trunk/MgDev/Server/src/Services/Kml/ServerKmlService.h&r2=946
File: trunk/MgDev/Server/src/Services/Kml/ServerKmlService.vcproj https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Kml/ServerKmlService.vcproj?view=diff&rev=946&p1=trunk/MgDev/Server/src/Services/Kml/ServerKmlService.vcproj&r1=945&p2=trunk/MgDev/Server/src/Services/Kml/ServerKmlService.vcproj&r2=946
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
