[mapguide][MG363][Modified] Direct KML Support in MapGuide
Chris Claydon
chris.claydon at autodesk.com
Mon Oct 30 18:09:07 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG363
Type:
Enhancement
Artifact ID:
MG363 (Direct KML Support in MapGuide)
Modified by:
Chris Claydon
chrisclaydon (chris.claydon at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG363 - Pass DPI resolution value into GetMapKml request
Modified
File: trunk/MgDev/Common/MapGuideCommon/Services/KmlService.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MapGuideCommon/Services/KmlService.h?view=diff&rev=950&p1=trunk/MgDev/Common/MapGuideCommon/Services/KmlService.h&r1=949&p2=trunk/MgDev/Common/MapGuideCommon/Services/KmlService.h&r2=950
File: trunk/MgDev/Common/MapGuideCommon/Services/ProxyKmlService.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MapGuideCommon/Services/ProxyKmlService.cpp?view=diff&rev=950&p1=trunk/MgDev/Common/MapGuideCommon/Services/ProxyKmlService.cpp&r1=949&p2=trunk/MgDev/Common/MapGuideCommon/Services/ProxyKmlService.cpp&r2=950
File: trunk/MgDev/Common/MapGuideCommon/Services/ProxyKmlService.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/MapGuideCommon/Services/ProxyKmlService.h?view=diff&rev=950&p1=trunk/MgDev/Common/MapGuideCommon/Services/ProxyKmlService.h&r1=949&p2=trunk/MgDev/Common/MapGuideCommon/Services/ProxyKmlService.h&r2=950
File: trunk/MgDev/Server/src/Services/Kml/OpGetMapKml.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Kml/OpGetMapKml.cpp?view=diff&rev=950&p1=trunk/MgDev/Server/src/Services/Kml/OpGetMapKml.cpp&r1=949&p2=trunk/MgDev/Server/src/Services/Kml/OpGetMapKml.cpp&r2=950
File: trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp?view=diff&rev=950&p1=trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp&r1=949&p2=trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp&r2=950
File: trunk/MgDev/Server/src/Services/Kml/ServerKmlService.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Kml/ServerKmlService.h?view=diff&rev=950&p1=trunk/MgDev/Server/src/Services/Kml/ServerKmlService.h&r1=949&p2=trunk/MgDev/Server/src/Services/Kml/ServerKmlService.h&r2=950
File: trunk/MgDev/Web/src/HttpHandler/HttpKmlGetMap.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/HttpHandler/HttpKmlGetMap.cpp?view=diff&rev=950&p1=trunk/MgDev/Web/src/HttpHandler/HttpKmlGetMap.cpp&r1=949&p2=trunk/MgDev/Web/src/HttpHandler/HttpKmlGetMap.cpp&r2=950
File: trunk/MgDev/Web/src/HttpHandler/HttpKmlGetMap.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/HttpHandler/HttpKmlGetMap.h?view=diff&rev=950&p1=trunk/MgDev/Web/src/HttpHandler/HttpKmlGetMap.h&r1=949&p2=trunk/MgDev/Web/src/HttpHandler/HttpKmlGetMap.h&r2=950
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
