[mapguide][MG442][New] Computed properties using Min() and Max() functions don't wo...
Bruce Dechant bruce.dechant at autodesk.com
Tue Oct 31 18:18:08 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG442
Type
 Defect
Artifact ID
 MG442 (Computed properties using Min() and Max() functions don't work with string values)
Reported by
 Bruce Dechant
 brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Description set to new value
  Computed properties using Min() and Max() functions don't work with string values when used with SelectFeatures and SelectAggregate APIs
- Steps to Reproduce set to new value
  Setup a SelectFeatures or a SelectAggregate and specify a computed property using the Min() or Max() function on a string value. The results returned are not what you expect as the Min() and Max() functions only support numeric values.
- Artifact Status set to new value
  New
- Subcomponent set to new value
  Feature Service
- Version set to new value
  1.0.1
- Priority set to new value
  P3
- Operating system set to new value
  All
- Artifact created
- Summary set to new value
- Defect Severity set to new value
  Medium
- Component set to new value
  Server
- Platform set to new value
  All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
