[mapguide][MG377][New] Port MapGuide to Platform API code base on Linux
Ronnie Louie
ronnie.louie at autodesk.com
Fri Sep 1 16:12:06 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG377
Type
Enhancement
Artifact ID
MG377 (Port MapGuide to Platform API code base on Linux)
Reported by
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Testing Notes set to new value
Server starts and works with the html test pages and SiteAdmin. Loaded Sheboygan sample data, and able to view map, but weblayouts didn't work. Loaded an SDF layer and was able to preview, but could not create a new map.
Server unit tests: 380/380 tests OK
Webtier unit tests: not run yet
- Summary set to new value
- Target milestone set to new value
1.1.0
- Description set to new value
The Linux build needed to be updated to build against the Platform API submitted with artifact MG367.
- Artifact created
- Priority set to new value
P3
- Artifact Status set to new value
New
- Related Artifacts set to new value
MG367
- Developer Notes set to new value
This initial submission fixes the build on Linux.
However there still remains some issues preventing the Server from being fully functional. See Testing Notes.
Also includes update to Makefile.am files to use AM_CXXFLAGS instead of CXXFLAGS which will allow these flags to be customizeable at build time.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
