[mapguide][MG378][New] Ability to localize web layouts
Tom Fukushima tom.fukushima at autodesk.com
Wed Sep 6 12:10:54 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG378
Type
 Enhancement
Artifact ID
 MG378 (Ability to localize web layouts)
Reported by
 Tom Fukushima
 tomfukushima (tom.fukushima at autodesk.com)
New artifact details:
- Artifact created
- Summary set to new value
- Artifact Status set to new value
  New
- Description set to new value
  Currently a web layout is only authored in a single locale.  This means that all of menu item names and tooltips are only definable in a single language.  We should be able to use the LOCALE parameter in the web layout URL to use the proper strings. This would also mean the the web layout resource would need to change so that it can store localized versions of the strings.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
