[mapguide][MG361][Modified] Correct some out of sync test vectors for the web unit tests...
Trevor Wekel
trevor.wekel at autodesk.com
Fri Sep 8 12:47:46 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG361
Type:
Task
Artifact ID:
MG361 (Correct some out of sync test vectors for the web unit tests.)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Review Comments set to new value:
Looks ok.
-- Submission Reviewed set to new value:
Yes
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
