[mapguide][MG377][Modified] Port MapGuide to Platform API code base on Linux
Trevor Wekel trevor.wekel at autodesk.com
Mon Sep 11 12:56:22 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG377
Type:
Enhancement
Artifact ID:
MG377 (Port MapGuide to Platform API code base on Linux)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Submission Reviewed set to new value:
Yes
-- Review Comments set to new value:
Looks good.  Can you also switch the Windows build to use the new Build.cpp files?
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
