[mapguide][MG385][New] Allow MdfParser to serialize without indentation
Ben Trumbore ben.trumbore at autodesk.com
Tue Sep 12 14:37:51 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG385
Type
 Defect
Artifact ID
 MG385 (Allow MdfParser to serialize without indentation)
Reported by
 Ben Trumbore
 bentrumbore (ben.trumbore at autodesk.com)
New artifact details:
- Version set to new value
  1.0.1
- Steps to Reproduce set to new value
  I guess this is somewhere between a defect and new functionality...
- Summary set to new value
- Artifact created
- Defect Severity set to new value
  Medium
- Description set to new value
  Currently, MdfParser serializes all maps and layers using indentation (two spaces per indentation).  When using its own copy of MdfParser, Autodesk Map eliminated this indentation so the length of XML layer strings could be minimized.  Now that Map uses the OSGEO MdfParser, it is necessary to create a toggle for the indentation functionality.
- Artifact Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
