[mapguide][MG388][New] MapAgent does not exit cleanly when aborted by FastCGI
Steve Dang
steve.dang at autodesk.com
Wed Sep 13 19:25:29 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG388
Type
Defect
Artifact ID
MG388 (MapAgent does not exit cleanly when aborted by FastCGI)
Reported by
Steve Dang
stevedang (steve.dang at autodesk.com)
New artifact details:
- Priority set to new value
P2
- Component set to new value
Web Server Extensions
- Summary set to new value
- Steps to Reproduce set to new value
The Studio unit tests and other HTTP tests return sporadic failures. Loads tests show a regular HTTP request failure at 300 seconds when the MapAgent is torn down by mod_fastcgi or the isapi fcgi extension.
- Defect Severity set to new value
High
- Platform set to new value
All
- Operating system set to new value
All
- Target milestone set to new value
1.0.2
- Description set to new value
MapAgent does not exit cleanly when aborted by FastCGI.
This defect is due to overly aggressive teardown logic in the FastCGI client library that we link to the agent. The library should be changed to use a more application friendly teardown mechanism.
- Subcomponent set to new value
Map Agent
- Artifact Status set to new value
New
- Version set to new value
1.0.1
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
