[mapguide][MG389][New] Server does not log errors for layers that fail to be styliz...
Bruce Dechant
bruce.dechant at autodesk.com
Thu Sep 14 16:33:49 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG389
Type
Defect
Artifact ID
MG389 (Server does not log errors for layers that fail to be stylized)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Artifact created
- Operating system set to new value
All
- Subcomponent set to new value
Mapping Service
- Target milestone set to new value
1.1.0
- Platform set to new value
All
- Description set to new value
If a layer fails to be stylized by the server there is no entry in the server's error log file to indicate anything went wrong.
- Steps to Reproduce set to new value
Create a map with a valid layer. Now delete the layer and refresh the map. Nothing is displayed in the map as expected, but there is no error logged indicating anything went wrong.
- Defect Severity set to new value
High
- Component set to new value
Server
- Summary set to new value
- Version set to new value
1.0.1
- Artifact Status set to new value
New
- Priority set to new value
P2
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
