[mapguide][MG390][New] Spatial context association of the geometry property not bei...
Bruce Dechant
bruce.dechant at autodesk.com
Thu Sep 14 17:33:26 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG390
Type
Defect
Artifact ID
MG390 (Spatial context association of the geometry property not being used)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
Create a layer against a feature source that contains more than 1 spatial context with the one you are interested in marked as inactive or not the 1st one in the list returned.
- Defect Severity set to new value
High
- Description set to new value
The server does not use the spatial context association of the geometry property to determine which spatial context to use. Currently, the server defaults to using the 1st active spatial context returned. In some cases this will cause the server to use the wrong spatial context or to not even have access to the proper spatail context because the real one needed was not marked as active. The fix for this is to use the spatial context referenced by the geometry property itself regardless of being active or not.
This needs to be corrected.
- Platform set to new value
All
- Summary set to new value
- Component set to new value
Server
- Artifact Status set to new value
New
- Priority set to new value
P2
- Artifact created
- Version set to new value
1.0.1
- Operating system set to new value
All
- Target milestone set to new value
1.1.0
- Subcomponent set to new value
Mapping Service
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
