[mapguide][MG396][New] Logos are not displayed on a page created by Print tool in W...
Bruce Dechant bruce.dechant at autodesk.com
Tue Sep 19 17:41:29 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG396
Type
 Defect
Artifact ID
 MG396 (Logos are not displayed on a page created by Print tool in Web Layout and in Preview in a browser (using DWF viewer))
Reported by
 Bruce Dechant
 brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Defect Severity set to new value
  Medium
- Artifact created
- Version set to new value
  1.0.1
- Steps to Reproduce set to new value
  Studio and MapGuide server build 178.26, DWF viewer build 928.0
1. Open New Print Layout template in Studio.
2. Change  <ShowCustomLogos> to true in <LayoutProperties>.
3. Update the path pointing to symbol in Symbol Library, symbol name, position and size.
4. When you've set up your custom logo(s), remove comment tags. from the template and save all these changes.
5. Attach this Print Layout into Print command in Web Layout.
6. Having selected DWF viewer as a default trigger Print command from Web Layout menu bar.
7. In opened Print UI select above modified Print Layout and Refresh preview.
Created custom Logo(s) are neither displayed in print preview and printed on printout.
- Target milestone set to new value
  1.1.0
- Subcomponent set to new value
  Mapping Service
- Operating system set to new value
  All
- Platform set to new value
  All
- Priority set to new value
  P3
- Component set to new value
  Server
- Artifact Status set to new value
  New
- Summary set to new value
- Description set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
