[mapguide][MG398][New] WMS GetFeature doesn't support SRS parameter (only CRS)
Chris Claydon chris.claydon at autodesk.com
Tue Sep 19 17:59:41 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG398
Type
 Defect
Artifact ID
 MG398 (WMS GetFeature doesn't support SRS parameter (only CRS))
Reported by
 Chris Claydon
 chrisclaydon (chris.claydon at autodesk.com)
New artifact details:
- Defect Severity set to new value
  Medium
- Steps to Reproduce set to new value
  Make a WMS GetFeatureInfo request using the SRS parameter. Observe the error regarding the coordinate system.
- Artifact created
- Description set to new value
  WMS GetFeatureInfo requests made using the SRS parameter currently fail, because the web tier request parsing code only looks for "CRS" for this type of request.
GetMap currently supports either SRS or CRS, and GetFeatureInfo should be modified to behave the same way.
- Summary set to new value
- Component set to new value
  Web Server Extensions
- Operating system set to new value
  All
- Platform set to new value
  All
- Artifact Status set to new value
  New
- Version set to new value
  1.0.1
- Subcomponent set to new value
  OGC Interface
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
