[mapguide][MG395][Modified] AJAX Viewer launches EN help instead of localized help
Chris Claydon chris.claydon at autodesk.com
Tue Sep 19 18:07:27 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG395
Type:
Defect
Artifact ID:
MG395 (AJAX Viewer launches EN help instead of localized help)
Modified by:
Chris Claydon
chrisclaydon (chris.claydon at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Status Explanation set to new value:
Code fix
-- Resolution Description set to new value:
Fixed code to use LOCALE parameter
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
