[mapguide][MG385][Modified] Allow MdfParser to serialize without indentation
Ben Trumbore
ben.trumbore at autodesk.com
Mon Sep 25 16:29:23 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG385
Type:
Defect
Artifact ID:
MG385 (Allow MdfParser to serialize without indentation)
Modified by:
Ben Trumbore
bentrumbore (ben.trumbore at autodesk.com)
The following modifications were made to this artifact:
-- Developer Notes set to new value:
In response to reviewer comments, the method of producing the indentation string was changed to eliminate a potentially time consuming loop.
The DisableTabs method was also added to the FSDSAX2Parser class for use when serializing feature sources.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
