[mapguide][MG403][Modified] Add tags for SWIG generation of automatic .NET properties fo...
Ronnie Louie
ronnie.louie at autodesk.com
Tue Sep 26 01:03:29 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG403
Type:
Enhancement
Artifact ID:
MG403 (Add tags for SWIG generation of automatic .NET properties for Platform API)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
Tags added for SWIG generation to support .NET automatic properties for Platform API objects.
New value:
Tags added for SWIG generation to support .NET automatic properties for Platform API objects. NUnit tests added to verify object property accessors.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
