[mapguide][MG157][Modified] Annoyance: DWF viewer samples behaviour changed by Microsof...
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Sep 27 07:25:37 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG157
Type:
Defect
Artifact ID:
MG157 (Annoyance: DWF viewer samples behaviour changed by Microsoft KB912945 update)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Submission Reviewed set to new value:
Yes
-- Resolution Description set to new value:
Old value:
There are two parts to this.
1/ Fixing MapGuide's web surround to use the workaround from Microsoft - this was fixed with submission MG72.
2/ Fixing DWF Viewer - it uses embedded controls and the same workaround needs to be applied here. The next release of DWF Viewer will have this fixed (the fix for EMap has been submitted).
New value:
DWF Viewer 7 addresses this issue.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
