[mapguide][MG404][New] AJAX Viewer .NET Version - Measure command fails on French O...
Chris Claydon chris.claydon at autodesk.com
Wed Sep 27 16:10:26 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG404
Type
 Defect
Artifact ID
 MG404 (AJAX Viewer .NET Version - Measure command fails on French OS)
Reported by
 Chris Claydon
 chrisclaydon (chris.claydon at autodesk.com)
New artifact details:
- Component set to new value
  Web Server Extensions
- Description set to new value
  When running the .NET version of the web extensions on a French operating system, the Measure command fails when attempting to parse a numerical value that uses a comma as the decimal point.
- Subcomponent set to new value
  AJAX Viewer
- Artifact Status set to new value
  New
- Version set to new value
  1.0.1
- Operating system set to new value
  Windows XP
- Artifact created
- Summary set to new value
- Defect Severity set to new value
  High
- Steps to Reproduce set to new value
  On a French OS using .NET web extensions create a web layout and use the Measure command.
- Platform set to new value
  All
- OS Distribution and Version set to new value
  French
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
