[mapguide][MG404][Modified] AJAX Viewer .NET Version - Measure command fails on French O...
Chris Claydon chris.claydon at autodesk.com
Wed Sep 27 16:17:04 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG404
Type:
Defect
Artifact ID:
MG404 (AJAX Viewer .NET Version - Measure command fails on French OS)
Modified by:
Chris Claydon
chrisclaydon (chris.claydon at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG404 - Fix AJAX viewer problems when numbers are accidentally converted to localized string format.
Modified
File: trunk/MgDev/Web/src/mapviewernet/buffer.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/buffer.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/buffer.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/buffer.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/bufferui.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/bufferui.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/bufferui.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/bufferui.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/common.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/common.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/common.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/common.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/legend.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/legend.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/legend.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/legend.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/mainframe.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/mainframe.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/mainframe.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/mainframe.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/mapframe.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/mapframe.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/mapframe.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/mapframe.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/measure.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/measure.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/measure.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/measure.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/measureui.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/measureui.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/measureui.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/measureui.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/search.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/search.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/search.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/search.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/selectwithinui.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/selectwithinui.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/selectwithinui.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/selectwithinui.aspx&r2=832
File: trunk/MgDev/Web/src/mapviewernet/viewoptions.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/viewoptions.aspx?view=diff&rev=832&p1=trunk/MgDev/Web/src/mapviewernet/viewoptions.aspx&r1=831&p2=trunk/MgDev/Web/src/mapviewernet/viewoptions.aspx&r2=832
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
