[mapguide][MG406][New] Identity properties are not being retrieved correctly which ...
Bruce Dechant
bruce.dechant at autodesk.com
Thu Sep 28 18:30:32 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG406
Type
Defect
Artifact ID
MG406 (Identity properties are not being retrieved correctly which leads to all features being selected when using the AJAX viewer)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Platform set to new value
All
- Component set to new value
Server
- Defect Severity set to new value
High
- Artifact created
- Priority set to new value
P2
- Version set to new value
1.0.1
- Operating system set to new value
All
- Subcomponent set to new value
Feature Service
- Description set to new value
The MapGuide server code is not properly returning the identity properties when dealing with feature sources that contain more then one feature class.
This can cause all the features to be selected when using the AJAX viewer and performing selection of a single feature.
- Target milestone set to new value
1.0.2
- Steps to Reproduce set to new value
1) Setup a feature source that contains multiple feature classes.
2) Ensure that the 1st feature class in the list does not have the same identity properties as any of the other feature classes.
3) Create a layer against this feature source, but select any feature class other than the 1st one.
4) Try and select a single feature using the AJAX viewer and observe that all the features are selected.
- Summary set to new value
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
