[mapguide][MG407][New] Connection pooling causes joins to fail
Ronnie Louie ronnie.louie at autodesk.com
Thu Sep 28 18:32:31 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG407
Type
 Defect
Artifact ID
 MG407 (Connection pooling causes joins to fail)
Reported by
 Ronnie Louie
 ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Version set to new value
  1.0.1
- External ID set to new value
  832470
- Steps to Reproduce set to new value
  Preview a layer using a join, for example SDF and ODBC. The layer should preview. Attempt to zoom and nothing is shown. Several errors in the server error logs indicating "Cannot establish connection" are generated and the layer will no longer preview.
- Component set to new value
  Server
- Artifact Status set to new value
  New
- Defect Severity set to new value
  High
- Priority set to new value
  P2
- Artifact created
- Subcomponent set to new value
  Feature Service
- Description set to new value
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
