[mapguide][MG406][Modified] Identity properties are not being retrieved correctly which ...
    Bruce Dechant
    bruce.dechant at autodesk.com
    Fri Sep 29 14:14:58 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG406
Type:
Defect
Artifact ID:
MG406 (Identity properties are not being retrieved correctly which leads to all features being selected when using the AJAX viewer)
Modified by:
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
The following modifications were made to this artifact:
-- Build set to new value:
178.58
-- Resolution Description set to new value:
Code fix submitted.
-- Status Explanation set to new value:
Code fix submitted.
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
