[mapguide][MG353][Modified] WMS Calls to MapGuide Open fail with 1.0.1
Chris Claydon chris.claydon at autodesk.com
Fri Sep 29 17:35:34 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG353
Type:
Defect
Artifact ID:
MG353 (WMS Calls to MapGuide Open fail with 1.0.1)
Modified by:
Chris Claydon
chrisclaydon (chris.claydon at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG353 - Read PROJ_LIB from registry if read from environment variable fails
Modified
File: trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp?view=diff&rev=841&p1=trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp&r1=840&p2=trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp&r2=841
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
