road map planning
Paul Spencer
pspencer at dmsolutions.ca
Fri Oct 20 08:45:10 EDT 2006
All,
I'm keen to lay out the framework for a road map for MGOS. I have a
few suggestions to help us get organised. Primarily I think the road
map should be organised around the planned release schedule and
versions. Central to my proposal is the concept of version
numbering. We do need to have a version numbering discussion, so
I'll lay out my thoughts here.
A MGOS version number consists of 3 numeric fields separated by a
period, X.Y.Z <tag>. X is the major version number, Y is the minor
version number and Z is the bugfix release number. Version numbers
can be tagged with a descriptive title as well, for instance BETA or
RELEASE CANDIDATE.
Rules for changing version numbers on release need to be established,
here is my first cut at it (but it will need to be fleshed out some
more):
* Changes to the major version number happen when the software
undergoes substantial architectural changes and/or has a substantial
set of new features.
* Changes to the minor version number happen when the software
undergoes minor architectural changes, improved performance and
stability, some new features, or any changes to the existing
published API.
* Changes to the bugfix release number happen for bug fixes and
trivial changes.
Version numbers can be useful when laying out a road map, if we look
at the road map as a series of releases. The PSC can, at a high
level, agree on a release schedule and slot features etc into the
appropriate slots.
Timing of releases can be planned around the release numbers. I
propose that we adopt the MapServer release strategy, which is as
follows:
1. Release a minor version approximately every 6 months regardless of
what has been done. This has several advantages which I will only
bring up if the group disagrees with this strategy :)
2. Bug fix releases are then done approximately 'whenever' ...
essentially as often as needed, but typically one release within a
month or two of the minor release and then maybe one more before the
next minor release - depends on the stability of the software and the
criticality of the bug fix - sometimes MapServer waits to accumulate
several minor bugfixes and sometimes they release with only one major
bugfix.
3. Major version releases happen irregularly and depend on actual
features implemented. Essentially, enough stuff has to happen to
make it worthwhile.
My suggestion is that the PSC should be planning on major releases
somewhere between the .3 and .6 minor version of the previous major
release ... between 18 months and 3 years essentially, although it
could happen more quickly too.
Given all the preceding is ratified by the PSC (or some reasonable
facsimile), the outline of the road map for MGOS might be:
MapGuide 1 - Current
MapGuide 1.0.0 - Released ???
MapGuide 1.0.1 - Released ???
MapGuide 1.0.2 - Released Oct 14 2006
MapGuide 1.0.3 - as required
MapGuide 1.1.0 - December 2006
MapGuide 1.2.0 - June 2007
MapGuide 1.3.0 - December 2007
MapGuide 1.4.0 - June 2008
MapGuide 2 - Future
MapGuide 2.0.0 - Unscheduled
We would then start to accumulate wishlist suggestions and
tentatively slot them into minor and major releases. Due to the
nature of open source, we can't actually predict what will end up in
any given release because we need to find volunteers or contributors
to get each piece done.
But if we have a plan of what we would like to see, ADSK, DMSG and
others will be influenced by the road map and hopefully it will have
a greater chance of becoming reality :)
Cheers
Paul
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Mapguide_psc
