[mapguide-users] findparcelfunctions.aspx
    Chris Tallman
    ctallman at innomap.com
    Wed Apr  5 13:27:14 EDT 2006
Thanks Jason that did the trick.
One thing to note.  Copying the CoordinateSystemWkt tag directly does
not work.
Backslashes need to be entered.  See below.
Original text:
PROJCS["NAD_1983_StatePlane_Indiana_East_FIPS_1301_Feet",GEOGCS["GCS_Nor
th_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378
137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925
199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",328
083.3333333333],PARAMETER["False_Northing",820208.3333333333],PARAMETER[
"Central_Meridian",-85.66666666666667],PARAMETER["Scale_Factor",0.999966
6666666667],PARAMETER["Latitude_Of_Origin",37.5],UNIT["Foot_US",0.304800
6096012192]]
Edited text:
PROJCS[\"NAD_1983_StatePlane_Indiana_East_FIPS_1301_Feet\",GEOGCS[\"GCS_
North_American_1983\",DATUM[\"D_North_American_1983\",SPHEROID[\"GRS_198
0\",6378137.0,298.257222101]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",
0.0174532925199433]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"Fal
se_Easting\",328083.3333333333],PARAMETER[\"False_Northing\",820208.3333
333333],PARAMETER[\"Central_Meridian\",-85.66666666666667],PARAMETER[\"S
cale_Factor\",0.9999666666666667],PARAMETER[\"Latitude_Of_Origin\",37.5]
,UNIT[\"Foot_US\",0.3048006096012192]]";
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, April 05, 2006 12:44 PM
Subject: RE: [mapguide-users] findparcelfunctions.aspx
That OGC well known text representation of the LL84 Coordinate Reference
System (CRS) is being used to create the marker's SDF feature source:
    MgCreateSdfParams sdfParams = new MgCreateSdfParams("LL84", ll84Wkt,
parcelMarkerSchema);
    featureService.CreateFeatureSource(parcelMarkerDataResId,
sdfParams);
So I think that it would make sense that it's affecting your markers.
The CreateFeatureSource docs are here:
https://mapguide.osgeo.org/nonav/docs/webapi/d5/d10/class_mg_feature_ser
vice_ab9a61218e9ea48601edfde782272055.html
<https://mapguide.osgeo.org/nonav/docs/webapi/d5/d10/class_mg_feature_se
rvice_ab9a61218e9ea48601edfde782272055.html>
You can pull the spatial context for one of your existing layers through
the mapagent api tests.
 - Go to http://localhost/mapguide/mapagent/index.html
<http://localhost/mapguide/mapagent/index.html>
 - Click on "Resource service API" in the upper left pane
 - Click on "EnumerateResources " in the lower left pane
 - In the right pane, fill in "Library://" as the Resource ID and
"FeatureSource" as the Type and click on Submit.
 - Copy the contents of the <ResourceID> tag for the feature source with
your desired CRS into your clipboard.
    e.g. Library://Samples/Sheboygan/Data/CityLimits.FeatureSource
 - Click on "Feature service API" in the upper left pane
 - Click on "GetSpatialContexts " in the lower left pane
 - Paste the previously copied Resource ID into the Resource ID field in
the right pane and click on Submit
 - The WKT for your CRS should be revealed in the CoordinateSystemWkt
tag
Jason
From: Chris Tallman [mailto:ctallman at innomap.com]
Sent: Wednesday, April 05, 2006 08:57
Subject: [mapguide-users] findparcelfunctions.aspx
Can someone explain this line from the findparcelfunctions.aspx page.
String ll84Wkt = "GEOGCS[\"LL84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS
84\",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich
\",0],UNIT[\"Degrees\",1]]";
specifically does it need to be edited if I'm using a different
Coordinate system?  Say IN83-EF.
I think I have everything working with my map reusing the
findparcel.aspx other than the markers are not placed.  I think this
line may be placing the marker off the map.
Chris Tallman
260.407.1761
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060405/5432b485/attachment.html
More information about the Mapguide_users
