[mapguide-users] MapGuide Studio Preview Window
Alain Lebatard alain.lebatard at autodesk.com
Wed Apr 5 16:23:04 EDT 2006
Steven,
If you have an existing web layout in your repository, open it with
Studio's web layout editor, and click 'Go' to preview the web layout
within a web browser. If this is working then there is probably just a
problem with the configuration of the aliases "mapviewerajax" and
"mapviewerdwf" that Studio use for the preview window.
However If you see the same problem in the web browser as in the preview
window, then your web server is not properly configured to handle pages
with a php extension (or jsp or aspx depending on what you are using),
which causes these pages to be returned as text instead of being
executed. Tell us also if you are using Apache or IIS, and if you are
using PHP, JSP or ASP.NET.
Alain
  _____
From: Steven J Reed [mailto:sjreed at edcomputing.com]
Sent: Wednesday, April 05, 2006 12:47 PM
Subject: RE: [mapguide-users] MapGuide Studio Preview Window
Any suggestions as to why it doesn't????
  _____
From: Bill Dhimitri [mailto:bill.dhimitri at autodesk.com]
Sent: Wednesday, April 05, 2006 12:41 PM
Yes.  It should work.
  _____
Sent: Monday, April 03, 2006 5:05 PM
Subject: [mapguide-users] MapGuide Studio Preview Window
Is this supposed to be working?  Mine just shows html source, not any of
the resources that are defined.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060405/62d02aa2/attachment.html
More information about the Mapguide_users mailing list
