SV: [mapguide-users] WFS-request does not work? - Problem solved
Tisén Tommy Tommy.Tisen at sweco.se
Fri Apr 7 09:26:52 EDT 2006
Problem Solved...
 The reason why got this error was when i loaded the layers i unchecked the box "Convert to SDF feature source". Why i did this was that i didnt get any response from my WFS service, so I tried everything i could think of.
The problem was only (which has been mentioned at this list before): Go to Properties for your Data  -  then Service Properties - Check the box "Public via Web Feature Service" and fill in something in the "keyword" field.
No problem anymore.
/Tommy Tisén
Från: Tisén Tommy [mailto:Tommy.Tisen at sweco.se]
Skickat: den 6 april 2006 10:29
Till: users at mapguide.osgeo.org
Ämne: [mapguide-users] WFS-request does not work?
Hi list,
I have a problem when asking my mapguide a simple WFS-request.
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetCapabilities
It returns:
An exception occurred in FDO component. SDF connect failed. File does not exist or cannot be opened in specified access mode.
An exception occurred in FDO component. SDF connect failed. File does not exist or cannot be opened in specified access mode. Exception occurred in method MgFdoConnectionManager.Open at line 840 in file c:\build_tux_area\mgdev\server\src\common\manager\FdoConnectionManager.cpp
What seems to be the problem?
/TOTI
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060407/a6e4d009/attachment.html
More information about the Mapguide_users mailing list
