[mapguide-users] Win2003 fcgi Install Issue and Solution
Jason Birch
Jason.Birch at nanaimo.ca
Fri Apr 7 19:33:32 EDT 2006
Looks like we're head-banging in unison; I just ran into the same thing.
I did the fix that you stated, but I also had to add the isapi handler
to my Web Service Extensions. I must have manually set up the .exe
version last time, or maybe removed too many settings when cleaning up
my old uninstall.
The Make Package function is very cool. I wonder if it can be
automated...
Jason
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, April 07, 2006 16:27
Subject: [mapguide-users] Win2003 fcgi Install Issue and Solution
I just experienced one of those maddening installation issues where a
1/2 hour upgrade turns into a couple of hours of banging my head on my
keyboard. This was a Windows 2003, IIS6 and .NET web extension
installation. I uninstalled the prior version and confirmed that the
virtual and physical directories had been removed. I then installed the
new version opting to have it configure IIS with .NET. Upon testing,
any calls to the .fcgi mapagent resulted in a 404 page not found error.
I finally traced the problem to the following:
In the mapagent virtual directory in IIS, under Configuration,
Application extensions, the .fcgi extension was configured as:
c:\PROGRA~1\MAPGUI~1\WEBSER~1\www\mapagent\ISAPI_~1.dll. When I changed
it to the long path of "C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapagent\isapi_fcgi.dll
", it mysteriously started working. I checked at the command prompt
using the dir /x command to make sure that the short name was valid, and
it all looked OK. So, I have no idea why using the long path and
filename solved the problem, but it did. On this server, I can readily
replicate the problem by substituting back in the short path and
filename.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com <http://www.SpatialGIS.com>
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060407/e2ee9634/attachment.html
More information about the Mapguide_users
