[mapguide-users] How can I connect to my server with a WMS connection??
Bill Dhimitri
bill.dhimitri at autodesk.com
Mon Apr 10 08:37:50 EDT 2006
Hi Willem,
One thing that might cause the problem that you are seeing is this:
When installing the new MG Server or MG Studio, you must use these
steps:
1. Uninstall the old one.
2. Delete the folder that the old one was
installed in.
3. Install the new one.
If you skip step 2, it is possible that old DLLs will remain and affect
the way that the new version works. This is particularly true with FDO
DLLs.
Bill
_____
Sent: Monday, April 10, 2006 4:35 AM
Subject: RE: [mapguide-users] How can I connect to my server with a WMS
connection??
This is the error message:
Failed to retrieve message for "MgFdoException". Failed to retrieve
message for "MgFormatInnerExceptionMessage".
message for "MgFormatInnerExceptionMessage". Exception occured in method
MgFdoConnectionManager.Open at line 912 in file
c:\build_tux_area\mgdev\server\src\common\manager\FdoConnectionManager.c
pp
_____
Van: Willem Schwarte [mailto:willem at giskit.nl]
Verzonden: maandag 10 april 2006 10:17
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] How can I connect to my server with a
WMS connection??
And what about WFS?
Changing the service type in URL below, results in an error.
_____
Van: Bill Dhimitri [mailto:bill.dhimitri at autodesk.com]
Verzonden: vrijdag 7 april 2006 15:46
WMS connection??
Willem,
If you installed the Sheboygan sample data, then you can try this.
Enter this URL into your web browser (replacing the "localhost" with
your server name if necessary):
http://localhost/mapguide/mapagent/mapagent.fcgi?SERVICE=WMS&VERSION=1.0
.0&REQUEST=GetCapabilities
Bill
_____
Sent: Friday, April 07, 2006 8:36 AM
Subject: [mapguide-users] How can I connect to my server with a WMS
connection??
It seems i can connect, but i get a XML error.. To what URL do I
connect? How does this work, is there any info on setting this up?
Willem
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060410/be6de95b/attachment.html
More information about the Mapguide_users
