[mapguide-users] reached hello map ex/ how do i setup my directory structure
Dongjin Xing
Dongjin.Xing at autodesk.com
Mon Apr 10 16:04:39 EDT 2006
Let's assume that you already installed and configured your server and
web extension properly. So you are able to view the Sheboygan data in
the Studio.
It seems to me what you need to do is to copy all the dlls under
WebServerExtensions \www\mapviewernet\bin to
WebServerExtensions\www\dotnetviewersample\bin
Dongjin Xing
Autodesk Developer Network
_____
From: shailesh [mailto:shailesh at simplexindia.com]
Sent: Monday, April 10, 2006 1:10 AM
Subject: [mapguide-users] reached hello map ex/ how do i setup my
directory structure
hi,
i coud compose a weblayout and was also able to invoke script and the
hellomap example and everything works fine.
i would now like to setup my web site directories
1) where should i create the parent directory ? in www folder ? can it
the references be vailid to the libraries etc
i could not get the ajaxviewersample work when i copied it to the
devguide folder. i had copied the utilityfunctions etc in te same folder
i got an error in the line <%@ import namespace=osgeo.mapguide %>
Server Error in '/WISEOS' Application.
Compilation Error
Description: An error occurred during the compilation of a resource
required to service this request. Please review the following specific
error details and modify your source code appropriately.
Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could
not be found (are you missing a using directive or an assembly
reference?)
Source Error:
Line 17: <%@ Import Namespace="System.Collections" %>
Line 18: <%@ Import Namespace="System.IO" %>
Line 19: <%@ Import Namespace="OSGeo.MapGuide" %>
Line 20: <script language="c#" runat="server">
Line 21:
Source File: d:\Projects\WISEOS\devguide\utilityfunctions.aspx Line: 19
What should be the directory structure for an independent application
that i building now
2) how will be my website url look like if create a directory say
"MYMapguide" and the name of mysite is http://www.mywebsite.com
at this stage i just need to display the map how will the url look like
i mean earlier my application url was
http://www.mysite.com/mymapguide/showmap.asp that when i was using
classic asp, i had used the object tag and embeded the viewer
I would like to start developing my application now that the weblayout
is ready. how should i start building , storing files and maps etc
please help
regards
shailesh
--------------------------------------------------------------------- To
unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060410/3f717608/attachment.html
More information about the Mapguide_users
