MapGuide OS with Google Earth
Andy Morsell amorsell at spatialgis.com
Tue Apr 11 11:37:11 EDT 2006
Is this a limitation of the PHP web extensions only?  I am using the .NET web
extensions and I have similar functionality programmed in .NET
(https://mapguide.osgeo.org/livegallery.html) and can display well over 100
features in the KML (KMZ in my case).  I also just checked with some older
PHP code based on the same code you are using from Jason Birch and I see the
same thing, well over 100 features in the KML.  In this case, it is still
using the .NET web extensions but just PHP accessing the API.
View this message in context: http://www.nabble.com/RE%3A-MapGuide-OS-with-Google-Earth-t1425312.html#a3864292
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users mailing list
