[mapguide-users] ODBC problem...
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue Apr 11 12:57:02 EDT 2006
I got this:
An exception occurred in FDO component. RDBMS: No current open database.
Exception occurred in method MgFdoConnectionManager.Open at line 912 in
file
c:\build_tux_area\mgdev\server\src\common\manager\FdoConnectionManager.cpp
Andrew
Joel Carranza wrote:
> Well, the first time I tried this, I got a short reply of "False" and
> then the MapGuide service crashed. Nothing reported in any of the
> error logs. Restarted and ran again.
> I got the following:
> An exception occurred in FDO component. Bad parameter to method.
> in file
> Any ideas?
> --Joel
> *From:* Tom Fukushima [mailto:tom.fukushima at autodesk.com]
> *Sent:* Tuesday, April 11, 2006 9:31 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* RE: [mapguide-users] ODBC problem...
> Hi Andrew,
> The diagnostic information that shows up in the test connection
> information area is not very useful (this problem has been fixed
> recently but is not in Studio 16802). Please try the following:
> 1) Open your browser to the HTML index of MapGuide web tier. It has
> the form: http://<servername>/mapguide/mapagent/index.html
> <http://%3Cservername%3E/mapguide/mapagent/index.html>. (Message
> https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=321
> <https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=321> also
> has information on how to get to these pages.)
> 2) Click on the Feature Service API link in the top left frame.
> 3) Click on the TestConnection link in the bottom left frame.
> 4) In the Resource ID field, type in the name of the ODBC feature
> source that you created. This should have the form
> Library://<path>/<name>.FeatureSource.
> 5) Press Submit
> The resultant web page should give information on why the connection
> is not working.
> Hope this helps,
> Tom
> *From:* Joel Carranza [mailto:jec at gatekeeper.com]
> *Sent:* Tuesday, April 11, 2006 10:29 AM
> *Subject:* Re: [mapguide-users] ODBC problem...
> I don't think that the project is just with Jet connections. I have
> been unable to get any kind of ODBC (access, Oracle ODBC) connection
> to work, resulting in an identical error. I get similar results using
> either the Data Source Name or Connection String options
> Joel Carranza
> Gatekeeper Systems
> Andrew DeMerchant wrote:
>> I've just installed the latest Mapguide, Mapserver, and Studio as
>> well as the ODBC and Raster providers. Everything working fine,
>> except the ODBC. I've got a Jet connection set up on my computer, and
>> the provider does find it...I select the data source name, save the
>> connection, and then try "Test Connection" and get some errors:
>> System.Net.WebException: The remote server returned an error: (559)
>> MgFdoException.
>> at
>> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.ExecutePendingGetRequestToString(Operation
>> operation)
>> at
>> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.TestConnection(String
>> resourceId, String provider, String connectionString)
>> at Autodesk.MapGuide.Studio.Site.FeatureSourceInfo.TestConnection()
>> at
>> Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.TestConnectionControl.buttonTestConnection_Click(Object
>> sender, EventArgs e)
>> Am I missing something here, or does it just not yet work with Jet
>> databases? My data source is totally fine, as it works with other web
>> apps that I have made.
>> Andrew
>> ps - Great work on the Raster provider!
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.506-453-1025
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
*Andrew DeMerchant*
ph.506-453-1025
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users
